Kodi crashes after changing interface
I’ve been using Estuary as my default skin. I hadn’t had any problem with it but I wanted to give Kodi a new look so I opted for Grid, which is impressive, elegant and clean.
Minutes later out of nowhere Kodi crashed. I’ve been seeing the memory info in SYSTEM and it consumes a lot, droppin gto sub 70MB. Is this skin btoken or is it consumed-heavy? Enabled the debugging log and here’s the info recollected.
https://paste.kodi.tv/tuyuyiraka.kodi
Did you look at the developer’s page for this skin on the Kodi forums? Seems that development has been abandoned and other users are reporting issues as well. If you insist, you can adjust GPU_mem to 320 rather than the default 256 and test for improvement.
Thanks. Will look into that
