Kodi doen'st launch after update. (sad smiley)
Hi, after the last update (done today), and after et reboot of the raspberry I just have a sad smiley.
Before reboot I’ve done a sync via ssh.
here is the log > http://paste.osmc.io/setuzocena.xml
Any idea ?
Thx
10:17:55 642.887268 T:3024904752   ERROR: SQL: [Addons20.db] The database disk image is malformed
                                            Query: SELECT idVersion FROM version
You damaged your database either you have a file corruption or you didn’t wait long enough to have all database files being upgraded. Check which files you have in the the database folders and which timestamp they have.
Thank you for the reply,
I deleted the adddon20.db, reboot and it’s ok no.
THx :slightly_smiling:
