Since yesterday kodi doesnt actualize the databank with new Films. I Tag my Films on pc with TMM and let actualize the Database only local on my Vero4k, But now, the Filmnames and the Moviesubribe Will Not be Shown.what can be the Solution
reboot the OSMC device
reproduce the issue
upload the log set either using the
I have uploaded the log
When you upload, you get a URL, which you share here
We need complete logs, not just the Kodi logs.
2019-06-16 10:51:02.693 T:3868189408 WARNING: Process directory '/media/Musik/Bravo Hits/08 Bravo Hits 8/' does not exist - skipping scan. 2019-06-16 10:51:02.693 T:3535794912 ERROR:
Did you change the location/names? Then you need to do a clean library
The Problem is gone !
Solved myself, TMM has created Movie.nfo but Not the Info with the moviename, i made it manually — thanks for your support
