Kodi Freezing
I’m having freezing issues when my V5 is idle for a short length of time.
I can’t even ssh into it. Only thing I can do is pull the power plug, but that has sometimes caused it to become corrupted and need a fresh reload.
I noticed in another thread that Sam mentioned checking the power supply. I think I may be using my 4k power supply but has I have both 4k’s and v5 not sure how to tell the difference.
I’m running kodi V20.5
Just swap the PSU’s between the two units and see if the problem follows.
The specifications of the PSU are the same (5V, 2A), so you can’t harm your device by swapping them interchangeably.
