Kodi Frozen
Hello,
I have a Vero4k and kodi is frozen. I do not know how to get it working again.
How this happened? I added a new shared folder that I created in my NAS. To do this I added one line to the file auto.smb.shares. It was one line just like the one I had for the other shared folder.
After doing that when I access kodi in my TV it does not work. No button in the remote has any effect. The clock in the upper right corner advances. Rebooting has no effect.
I have removed the line I added in auto.smb.shares, but no difference.
Any idea on what can I do?
Thanks in advance
Starting point provide debug enabled logs
Hello,
This is the link provided by the grab log command:
https://paste.osmc.tv/wixizorobe
Regards,
Well last items in the log point out to an issue with your addon data directory
2023-09-16 12:51:26.292 T:2892    error <general>: GetDirectory - Error getting /home/osmc/.kodi/userdata/addon_data/pvr.hts/
2023-09-16 12:51:26.292 T:2892    error <general>: GetDirectory - Error getting special://profile/addon_data/pvr.hts/
2023-09-16 12:51:26.294 T:2892    error <general>: GetDirectory - Error getting /home/osmc/.kodi/userdata/addon_data/pvr.iptvsimple/
2023-09-16 12:51:26.294 T:2892    error <general>: GetDirectory - Error getting special://profile/addon_data/pvr.iptvsimple/
2023-09-16 12:51:26.294 T:2892    error <general>: GetDirectory - Error getting /home/osmc/.kodi/userdata/addon_data/pvr.nextpvr/
2023-09-16 12:51:26.294 T:2892    error <general>: GetDirectory - Error getting special://profile/addon_data/pvr.nextpvr/
2023-09-16 12:51:26.294 T:2892    error <general>: GetDirectory - Error getting /home/osmc/.kodi/userdata/addon_data/pvr.sledovanitv.cz/
2023-09-16 12:51:26.295 T:2892    error <general>: GetDirectory - Error getting special://profile/addon_data/pvr.sledovanitv.cz/
2023-09-16 12:51:26.295 T:2892    error <general>: GetDirectory - Error getting /home/osmc/.kodi/userdata/addon_data/pvr.vbox/
2023-09-16 12:51:26.295 T:2892    error <general>: GetDirectory - Error getting special://profile/addon_data/pvr.vbox/
2023-09-16 12:51:26.296 T:2892    error <general>: GetDirectory - Error getting /home/osmc/.kodi/userdata/addon_data/pvr.vuplus/
2023-09-16 12:51:26.296 T:2892    error <general>: GetDirectory - Error getting special://profile/addon_data/pvr.vuplus/
Not sure if that is your problem but surely would be interisting what is the reason and if something else is broken in the userdata directory.
The only addons I am using are for subtitles and scraping. It is possible that I tried to use some other add on but that had to be years ago when I got the Vero and I never got anything to work. I vaguely recall trying to get youtube working inside Kodi. But everything was working ok until now, so that does not seem to be related :frowning_face:
Regards,
Let’s test with Kodi default settings. Enter the following commands with an SSH connection.
systemctl stop mediacenter
mv ~/.kodi ~/kodi.bak
systemctl start mediacenter
If needed you can restore:
mv ~/.kodi ~/kodi.bk2
mv ~/kodi.bak ~/.kodi
If your original setup was restored as expected and you want get rid of the unneeded clean install you can delete that with the following command.
rm -r ~/kodi.bk2
Hello,
Thanks for the response but after doing that I get Kodi with the original skin (I understand all other settings have been lost) but it still does not respond to any button in the remote.
Regards
Ok, it was the remote not working. What are the chances that it happens just after I change a configuration for the first time in years…
Sorry for wasting your time.
Regards,
FYI that is just a bit of log spam that is normal at present. You will notice that those are all userdata config files for binary PVR add-ons that are present but disabled by default.
