I have 1gbit speed with ethernet connected. but if i want to stream with google drive, the 4K movies are continue buffering. it’s happens less with 1080P material, but the problem is still there. the vero 4k+ is up-to-date.
what should i do?
what should i do?
reproduce the issue
upload the log set (all configs and logs!) either using the Log Uploader
method within the My OSMC menu in the GUI or the ssh
method invoking command grab-logs -A
