I have a problem since a few weeks now.
Raspberry Pi 4 Model B Rev 1.1.
Here is the log from grab-logs -A, but bugged somehow: LOG
New added Movies and TV Shows are not scraped. But I can access and read them from the Video sources.
And I am not able to download subtitles anymore - the error message is that I apparently do not have any account. I just tried to uninstall Opensubtitles.org (which was installed) to download it again - the uninstallation worked apparently but impossible to download again. Same for any other add-on from the repository - it fails.
Thank you BanditRider, that works now. One less problem to solve , thanks.
fzinken,
interestingly, I just tried again the ping 8.8.8.8 and it looks fine (same for ping osmc.tv):
193 packets transmitted, 192 packets received, 0% packet loss
round-trip min/avg/max = 38.831/117.917/184.546 ms
That’s why I tried to download the Opensubtitles.com and it worked. Weird… Must have some unstable connection
Still, here is the ip ro output:
0.0.0.0/1 via 10.9.0.5 dev tun1
default via 192.168.1.1 dev eth0
10.9.0.1 via 10.9.0.5 dev tun1
10.9.0.5 dev tun1 proto kernel scope link src 10.9.0.6
10.9.0.21 dev tun0 proto kernel scope link src 10.9.0.22
128.0.0.0/1 via 10.9.0.5 dev tun1
185.212.226.142 via 192.168.1.1 dev eth0
185.212.226.153 via 192.168.1.1 dev eth0
192.168.1.0/24 dev eth0 proto kernel scope link src 192.168.1.54
192.168.1.1 dev eth0 scope link
I still have the scraping problem though, even with both TheMovieDatabase and Universal Movie Scraper.
Is this an older library and the shows that have scraping issues being ones that had existed in the library since before a major Kodi update? If so then the issue is probably they are set to source from TVDB and the update dumped the old non-working versions of the TVDB scraper and then Kodi defaulted back to installed scrapers. The solution would be to install the updated TVDB scrapers and then set your sources to use these, or else update you library to actually use the new source. I would recommend against switching to the universal scraper as it seems to be a bit more prone to issues. Switching the whole library can be a matter of dropping and rebuilding your TV show source, or can just be going to each of the shows with the issue and bring up the info screen (for the show, not an episode) and click the refresh option. If you have nfo files they would need to be removed or else they will just bring the wrong source back in.
If you want more details you can search the forum. I’ve covered this type of thing quite a few times now in detail.
Gut feeling is that you had (or have) a temporary issue with your network. That combined with the outdated subtitle/scraper settings confused a bit the resolution of the problem
