Hi there
Have been using Jarvis for some time and then I noticed the upgrade.
I actually deleted Jarvis as I needed to “tidy” up and so proceeded installing Krypton. However, it will not open. I have installed and uninstalled over the last 24 hours numerous times but it is still the same result…will not open. I also re-booted several times without success. Would welcome any assistance you can offer…thanks.
My PC is a mongrel build and is fast. I use Vivaldi brower.
