I just created a new OSMC build with kodi krypton beta 5. In this build I cant connect to the official kodi repo. Whenever I try to connect I get the following 404 error in my kodi.log file:
ERROR: CCurlFile::Open failed with code 404 for http://download.osmc.tv/kodi/addons/jarvis/krypton.xml.gz.md5
Any help would be appreciated, thanks.
Brad_Bruggemann:
Well if you create your own builds I would assume you know how to fix stuff. This specific issue was mentioned in the Beta release thread.
thanks for the quick reply.
