Hi all,
I tried to install Kodi 18 on my other raspberry pi 3
I followed this guide
Update: When OSMC stable is released it will be based on 18.1. The Nightly builds are now at 18.2RC1 so in order to avoid confusion its time to bump the nightly releases to 18.8
This requires that you update your sources.list and point to gmc-19. (See Installing below)
If you run the nightly 18.8 builds you will not automatically upgrade to 18.1 stable when it’s released (As the build number will be lower)
If you are having issues with updating this is due to the aptly certificate expiring. …
but got sad face after.
heris is link to my logs file
https://paste.osmc.tv/ozubopijem
i suspect this error is giving me problems
Jul 28 01:14:16 osmc mediacenter[11164]: /usr/lib/kodi/kodi.bin: error while loading shared libraries: libfstrcmp.so.0: cannot open shared object file: No such file or directory
thx for help!
fzinken
split this topic
28 July 2018 03:37
#2
