I posted this on the Kodi help forum and they told me to post it here because of “Kodi/OS system crashes happening”.
I am running OSMC and Kodi 19 on a Raspberry Pi 3B+. I made a playlist for about 500 music individual songs that are located on a USB hard drive NAS connected to my router. They are in 4 different directories and are wma, mp3, m4a or m4p files. I did this with the files approach and don’t have a library or anything extra, I just want to play back the music in a random order.
The playlist works for a while, then every so often after a dozen plays or fewer, I get the frowny face and the system restarts and goes to the main menu, terminating the playback. I’ve pasted the log file from the most recent incident at hastebin. I think from the log that incident involved an m4a file. I’ve since learned that the m4p files won’t play because of copy protection DRM and also result in a frowny face, but I thought the m4a files should be playable.
I’d appreciate any help in fixing this. I was also wondering whether the frowny face is coming from OSMC or Kodi?
Frowny Face comes from Kodi which is the main GUI system that runs on OSMC. As @sam_nazarko wrote we would need debug enabled logs (see below).
reproduce the issue
Thanks for your help. I had turned on the debug logging but didn’t know/remember to reboot. Do I need to turn on other options such as component-specific logging or event logging? For the upload, what is meant by the “log set (all configs and logs)”?
In the meantime, I’ve discovered that I can cause Kodi to crash pretty reliably by trying to play m4p files (which are DRM protected). So I will need to go through and eliminate those. I don’t think that will solve the problem based on what was in the original log, so will try to get you a better one.
I just wanted to provide the feedback that since I removed the DRM-protected m4p files from the playlist, I have so far not experienced any crashes. So I’m hopeful that solved the problem.
My sincere thanks to everyone for their kind and helpful advice.
