Hi there,
After the april update Kodi does not start up automatically anymore. The pi 1 works fine.
The Kodi log (5 last lines):
21:16:59 37.688992 T:3024622128 NOTICE: start dvd mediatype detection
21:17:10 48.836323 T:3024622128 WARNING: JSONRPC: Could not parse type “Setting.Details.SettingList”
21:17:11 49.546745 T:3024622128 NOTICE: ActiveAE DSP - starting
21:17:11 49.623840 T:3024622128 NOTICE: initialize done
21:17:11 49.624111 T:3024622128 NOTICE: Running the application…
Then it stops, Kodi has not started and the screen is black,
No addons running
Skin is confluence
No problem before the update.
Starting Kodi manually works: mediacenter start
Last lines of the kodi.log:
21:35:25 80.388718 T:3023852080 NOTICE: start dvd mediatype detection
21:35:27 82.374626 T:3023852080 WARNING: JSONRPC: Could not parse type “Setting.Details.SettingList”
21:35:27 82.720711 T:3023852080 NOTICE: ActiveAE DSP - starting
21:35:27 82.740433 T:3023852080 NOTICE: initialize done
21:35:27 82.740715 T:3023852080 NOTICE: Running the application…
21:35:27 82.984497 T:3023852080 WARNING: CPlayerCoreFactory::GetPlayerCore(audiodefaultplayer): no such core: omxplayer
21:35:34 90.215286 T:3023852080 WARNING: Previous line repeats 1 times.
21:35:34 90.215927 T:3023852080 NOTICE: starting zeroconf publishing
21:35:34 90.233047 T:3023852080 NOTICE: WebServer: Started the webserver
21:35:34 90.247971 T:3023852080 NOTICE: starting upnp client
21:35:35 90.341606 T:2720596976 NOTICE: ES: Starting UDP Event server on 127.0.0.1:9777
21:35:35 90.341988 T:2720596976 NOTICE: UDP: Listening on port 9777
21:35:37 92.301826 T:2816472048 WARNING: CPythonInvoker(3): Script invoked without an addon. Adding all addon modules installed to python path as fallback. This behaviour will be removed in future version.
21:35:47 102.828156 T:2881614832 WARNING: CSkinInfo: failed to load skin settings
Kodi runs.
Anyone?
