My current set up is a Kodi 15.0 with MySQL database running and I had raspbmc on my Raspberry Pi 1 B+. Also I was using the advancesettings.xml on my pi, then it decided to stop booting up (It went corrupt).
So I rebuilt it with OSMC loaded in the advancesettings.xml, turned on wait on network, set it to a static IP (wired) and it is not syncing TV shows and movies.
http://paste.osmc.io/ulivuvitaw
Is it conflicting with any other settings?
