Machou
1
Hello,
I have finish my movie, i stop it, and Kodi restart; and crash.
He restart, restart, restart with sad smiley face like : https://streamable.com/ma0xo5
My log : https://pastebin.com/7e41Xmyt
I have moved “.kodi” to “.kodi.bak” ; doesn’t work; crash
I have moved “MyVideos116.db” to “MyVideos116.db.bak”; doesn’t work; crash
My config :
Raspberry Pi 2
Debian 10.6
Kodi 18.6 with OSMC
I am lost. Can you help me please ?
Machou
3
I didn’t think to say it, because I tried it with an SD card that works and the raspberry also works because my SD with Recalbox works on it.
- i can connect to SSH via my PC on Ubuntu
- i have reinstall rbp2-mediacenter-osmc, mediacenter-skin-osmc & rbp-userland-osmc
- I have put my logs
- I have try to change SD card (cloned)
- I have check
sudo debsums --changed ( debsums 3.0.0 )
First launch :
root@osmc:/var/log# sudo mediacenter
Starting Kodi...
/usr/bin/mediacenter : ligne 142 : 3435 Erreur de segmentation sudo -u osmc LIRC_SOCKET_PATH=/var/run/lirc/lircd $KODI --standalone -fs
Kodi exited with return code 139 after 0 hours, 0 minutes and 1 seconds
sudo journalctl | paste-log : https://paste.osmc.tv/fufuvivuxe
sudo mount | paste-log : https://paste.osmc.tv/wimojoyiyu
sudo df -h | paste-log : https://paste.osmc.tv/opanadaqus
sudo grab-logs -A : https://paste.osmc.tv/nofiburiko
log of fsck /sb1 and fsck /sb2 : https://paste.osmc.tv/osuzamizil
After i reinstall :
sudo mediacenter
Starting Kodi...
/usr/lib/kodi/kodi.bin: symbol lookup error: /usr/lib/arm-linux-gnueabihf/libpython2.7.so.1.0: undefined symbol: PyEhc_UserWarning
Kodi exited with return code 127 after 0 hours, 0 minutes and 1 seconds
I am so Lost
I think what fzinken means is that you should install a fresh copy of OSMC onto a new SD card.
====================== Pi config =================== Ul2H1CLu
gpu_mem_1024=256
hdmi_ignore_cec_init=1
disable_overscan=1
start_x=1
disable_splash=1
gpu_mem_256=112
sdtv_aspect=1
gpu_mem_512=144
arm_freq=1160
core_freq=350
sdram_freq=310
---------------------- Pi config END --------------- Ul2H1CLu
I would try removing from your config.txt…
arm_freq=1160
core_freq=350
sdram_freq=310
Machou
6
I have try with another SD (1st sd don’t work, same for the 2nd, but the 3rd is the good), with Fresh install is good.
I have lost my big database but work.
Edit :
So I took the opportunity to do a big cleanup of my movies and series.
With the update and reinstallation, I gained speed. Kodi is 300% faster, it’s phenomenal.
In my opinion, all the useless addons I had were the cause of the slowdown.
In short, I’m finally happy with this unexpected / providential crash!
I need 3 months to recreate my database, but …
