I miss the cool Kodi Splash screens on the Vero (had them on my PC but not RPi3). Any chance we can get them back
I’m not sure that I have the splash to which you referm but I have one announcing the version of Kodi by using
<splash>true</splash>
in advancedsettings.xml
HTH
Derek
Will try that but i suspect its not the current Kodi Kryton man of steel splash
It should be
I’ve tested this on a clean build and yes it is there and working.
You simply need to edit ~/.kodi/userdata/advancedsettings.xml (create it if it’s not already there) and add the line that @dandnsmith mentioned. To edit this you’ll need to access the command line of your device or create/edit this file externally and copy it over, info on accessing the command line is here Accessing the command line - General - OSMC.
My advancedsettings.xml for instance looks like
<advancedsettings>
</advancedsettings>
Works. Thabks!
Happy to see you got there at last - I wasn’t sure what the ‘man of steel’ was.
Derek
I think he’s describing OSMC developers.
