Hi there,
I just wanted to know if there is anyone with the same issue ?
Random (mostly when the raspberry pi has been idle) the Kodi service freezes.
I can “fix” this with “systemctl restart mediacenter”, i’ve added two hardware buttons to the Pi.
One directly connected to the “hard reset” pins on the board, the otherone connected to two GPIO pins. Which, when shortend, run the command above.
Device: Raspberry Pi 2
Installation media: SDcard: 32 GB SDHC Card Class 10; Transcend TS32GSDHC10U1
Connection: Wired
Power Supply Type: adafruit 5V 10A switching power supply
Power specs: 5volt 10ampere
Peripherals: USB ir reciever (irc6 philips)
Storage Device: sftp [remote/www] also: mysql
OSMC version: 2015.07-1
XBMC version: 15.1 RC1
Codecs: mpeg2, WVC1
Audio/Video Output: HDMI (all codecs supported by reciever)
Overclocked: Nope
Config.txt Extras: Just the bought codes.
Aditional software: Just one cronjob that rsyncs some files once a day and script that “monitors” gpio pins for above mentioned reset button (for restarting kodi service)
