I’m using osmc on a rPI3 and from some time i’m experiencing a problem when starting kodi on it.
It takes (some times) several minutes to start kodi, after OSMC start.
Any help?
Any help?
Do you have wait for network enabled?
yes
Disable it.
Ok. I Will try it. Tks.
Didn’t solved. I did it right away and reboot OSMC and i’m still waiting for Kodi to start.
So, in summary:
Log Uploader
method within the My OSMC menu in the GUI or the ssh
method invoking command grab-logs -A
Thanks Tom.
Thanks you. I’m doing it now.
Best regards
The URL from the log is this:
HI,
20:14:10.566 T:1671426816 NOTICE: AddOnLog: PVR IPTV Simple Client: Playlist file path is not configured. Channels not loaded.
20:14:11.959 T:1671426816 NOTICE: Start - EPG thread started
20:14:12.667 T:1770181376 ERROR: CCurlFile::FillBuffer - Failed: Timeout was reached(28)
20:14:12.667 T:1770181376 ERROR: CCurlFile::Open failed with code 0 for http://feeds.openelec.tv/news
The 28 second delay for epg where playlist has not been configured may be causing an issue, I wouid try disabling IPTV simple.
When I ping the IP for feeds.openelec.tv, it fails. This may be slowing things down a bit as well.
Thanks Tom.
@kincas scratch that looks like your sdcard is failing, I would try a new sdcard.
