Kodi Tvguide Double Programs
OSMC November 2025.11-1
tvheadend serves from 10.0.3.100:9981, no issues or double channels in web gui, channels count is 333, matches my m3u8 file.
Using estuary skin, tvhclient is the only pvr enabled.
Selecting tvguide, all programs have double channels showing.
I’ve tried, deleting .kodi/userdata/Database/Epg16.db, restarting, no change, deleted .kodi, restart, no change.
So, other than enabling verbose logging, where or what to look at? In verbose logging, what are the indicators of this?
Are you sure the reason for the redundancy isn’t in your m3u8 file, e.g., the same channel is being imported via different network inputs?
You underline you’re using skin Estuary. What happens if you switch to skin OSMC for tests?
Did you get this resolved?
