Kodi v19 matrix Amazon VOD does not work
I’ve installed the update and dist-upgrade with apt-get on my vero 4k+. The Amazon Addon Sandmann79 for matrix doesn’t work.
Release Plugin Repository v1.0.4 · Sandmann79/xbmc · GitHub
It says the dependency on xbmc.python in version 2.2.5.0 could not be resolved and Mechanical soup says, the addon isn#t compatible with this Kodi version.
Can someone help me or should I wait for an update?
Netflix on the other hand works with these instructions, where I replaced python with python3 or pip3:
I had this problem. I was able to get rid of it by going through all the add on dependencies and uninstalling everything that was tagged as Orphaned.
Thanks for the reply.
I thought I had uninstalled everything relevant.
I will go through it again tomorrow.
You probably knew what I meant, but just in case: you get into the relevant list via Settings / System / Add-ons / Manage dependencies. Then go through the whole list and uninstall anything that says it’s orphaned.
Under Settings / System / Addons / I have no item with Manage dependencies and I can not find a list of addons.
(My system is in German, but that should make no difference…)
Now I don’t have time, but tonight I’ll go through the addons. .
:thinking:
Have you got your settings level set to Expert?
“Manage dependencies” should be just below “Show notifications” and above “Running”.
Under the item “Addon” I have the following, nothing else:
Updates
Show notifications
Unknown sources
Official addons update from
Reset above settings to default values
Where can I set “expert”?
I found the setting “expert”. Still looking…
Many, many thanks! :slight_smile:
Videos from Amazon are now running
