Hi all,
I just downloaded the latest version for the RaspberryPi 4 and can not use SFTP. I figured out that kodi does not include the SFTP addon by default and that I need to install kodi-vfs-sftp. Trying to install this package results in an error:
$ sudo apt install kodi-vfs-sftp
Reading package lists... Done
Building dependency tree... Done
rbp4-mediacenter-osmc : Conflicts: kodi
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
How should I install SFTP on OSMC?
OSMC version:
$ grep VERSION_ID /etc/os-release
VERSION_ID="2022.10-1"
Kodi version:
$ grep Kodi .kodi/temp/kodi.log | head -3
2023-01-14 21:54:59.689 T:546 INFO <general>: Starting Kodi (19.4). Platform: Linux ARM (Thumb) 32-bit
2023-01-14 21:54:59.689 T:546 INFO <general>: Using Release Kodi x32
2023-01-14 21:54:59.689 T:546 INFO <general>: Kodi compiled 2022-08-23 by GCC 10.2.1 for Linux ARM (Thumb) 32-bit version 5.10.78 (330318)
