I have a brand new 2017 XGODY Media Player Latest 17.3 Smart Android 6.0 TV BOX Network Streamer 4K box which is apparently running Krypton 17.3 and Android 6.0 Marshmallow. I would attach a screenshot of the main screen when I switch it on, if I only knew how
As you can probably tell I am a total newbie, and floundering. To add video add-ons, all the instructions start:
The first thing you need to do after launching Kodi Krypton is click on the Settings Icon in the top left corner.
Then, go to System Settings -> Expert Mode -> Addons.
Make sure to turn on ‘Unknown Sources.’ Otherwise, you will not be able to install third-party add-ons.
When the warning box pops up, click ‘Yes’.
But I don’t have a Settings Icon in the top left. That says Home. There is a Settings over on the right, a little way down, but thats not got System Settings!
Help, how can I find my way around the menu to install addons?
… thanks in advance!
