I upgraded and all seemed fine, until I rebooted and my Touchscreen display stopped working. I then disconnected this and rebooted with an HDMI display and this also did not work. So, I downgraded to the previous OSMC release and my displays worked again. I cannot provide logs because I can see anything on my displays when upgraded. So, I shall wait to see whether anyone else reports this problem.
Which display are you using? The official Pi Touchscreen?
You should be able to SSH in and grab logs.
Hi, I am using the official display as well as an external display, once the official display mis disconnected. I will have to learn how to obtaIn logs via SSH once I have attempted the rebuild in the next few weeks. Thank you for your help.
Details regarding how to access the command line interface can be found here on our Wiki: https://osmc.tv/wiki/general/accessing-the-command-line/
Thank you!!! What log /details of should I try to print?
Just ssh in and run grab-logs -A
Thank you !
