Lastest Update (Kodi 16) incompatible with TvHeadend 3.4.27 ...?
Hi everybody,
I’m running OSMC on a Rpi2 together with TvHeadend 3.4.27 on a Synology DiskStation. Tried the latest upgrade with Kodi 16 today and that leads to the PVR addon not working any more.
Logs are here
http://paste.osmc.io/sovedeqaco.coffee
17:31:05 146.206131 T:1428157424 ERROR: AddOnLog: Tvheadend HTSP Client: pvr.hts - server htsp version (v10) does not match minimum htsp version required by client (v19)
17:31:14 155.197693 T:1528820720 ERROR: Previous line repeats 1060 times.
17:31:14 155.197968 T:1528820720 ERROR: AddOnLog: Tvheadend HTSP Client: pvr.hts - failed to write (Invalid argument)
17:31:14 155.198196 T:1528820720 ERROR: AddOnLog: Tvheadend HTSP Client: pvr.hts - failed to transmit
17:31:14 155.198318 T:1528820720 ERROR: AddOnLog: Tvheadend HTSP Client: pvr.hts - failed to send hello
17:31:15 156.202805 T:1651504112 ERROR: ADDON: Dll Tvheadend HTSP Client - Client returned bad status (1) from Create and is not usable
Recovered 15.2 from the backup, then.
That looks like the new PVR addon in Kodi 16 not supporting that TvHeadend version any more. True? On a Synology it’s not that easy to get a newer version running.
I have the same problem, so I install the ver. 15.2 again
Seems pretty clear from the log that Kodi Jarvis needs a newer Tvheadend server.
Only options are updating the server or sticking with Kodi Isengard.
