So, freshly installed the July version using the OSMC installer on Friday, got everything cooking nicely. Did the October update, now every time I press a button on the remote, it’s doubled. No issues if I plug a keyboard in. I have tried disabling and re-enabling the remote and switching it off and on again.
PI3B (no plus), pukka MCE remote (not a clone), OSMC skin
Any thoughts and help gratefully received.
Thankis
***** UPDATE ******
It’s not doubling, it’s “+1ing”. If I press the remote twice quickly, the selector moves 3 times. 3=4 and 5=6.
Are you using a TSOP IR receiver or USB receiver? If the latter, try turning off MC6 decoding under Remotes.
Hi Sam,
Thanks for the reply. It’s the black IR receiver. I tried turning off RC6 in remotes, but it didn’t change anything.
I’ve updating the original post too, seems it’s not doubling, just adding 1 to each “set” of clicks, so if I click once there’s 2 moves, two clicks three moves, three clicks four moves.
Sounds like both the RC6 decoder and a remote profile are active.
Doesn’t seem to matter if the Disable RC6 box is ticked or not.
I plugged in another IR unit (an old one with no name, but I think it was in a Hauppage kit) and that works fine, and I remembered I had the app on the phone and that works fine too.
I’ll have another look at this when I get the next OSMC.
