Hello,
How can I install LEIA on a RPI2 with OSMC?
Is there some link to download the build to use with the osmc program?
thanks
Hello,
thanks
I’ve seen this post before [TESTING] Kodi 18 (Leia) builds for Raspberry Pi
but there is many commands in order to instal it! and im not used to work with them! so I don’t know how to do it!
Is there any build that I can use with the OSMC installer? thanks
No, as it is only in alpha testing. Official Release will only be later next year.
It is better to avoid it then. Leia builds are quite experimental and subject to breakage.
