I’m keen to upgrade to Leia (thanks for all the hard work Sam et al!) but have one concern - my TV/screen ONLY supports 1080p60hz - thus I’ve used
sudo fw_setenv hdmimode 1080p60hz
sudo fw_setenv outputmode 1080p60hz
to strongly encourage that resolution (1080p60hzforce also works but hasn’t been required).
Am just wondering what to expect after the upgrade - will that setting hold, and if it doesn’t, can I ssh into the box and use the same command to fix things?
Well, it’s working fine at present - and it’s a bit of a complicated can of worms that might well be best left sealed - but assuming the logs haven’t been deleted, then see this thread of mine: Interlaced output to progressive-only display?
