I am trying to get libcec/cec-client to work, and installed both libcec2 and cec-utils as per apt-get install.
The lib does not seems to be compiled for vero through?
osmc@osmc:~$ cec-client -i
libCEC version: 2.1.4, host: arm-unknown-linux-gnueabihf, features: ‘P8 USB’ ‘P8 USB detect’, compiled on: Thu Aug 7 18:08:13 UTC 2014 by buildd@hoiby.debian.org on Linux 3.15-trunk-armmp-lpae (armv7l)
osmc@osmc:~$ cec-client -l
Found devices: NONE
Is there anyone here successed with using cec-client for our vero4k ?
CEC is included and handled by OSMC automatically. You don’t need to install it manually. Doing so will probably give you an old upstream Debian version
I was installing the cec-utils, as i would like to try if i could switch between inputs on my TV this way; case is i have some problems with it’s ir-remote and TV cannot be controlled with “IP-Control” as many newer tv’s can… sadly!
When i reboot my vero, the input switch, so i guess it is working
osmc@osmc:~$ dpkg -l | grep cec
ii cec-utils 4.0.1+dfsg1-1 armhf USB CEC Adaptor communication Library (utility programs)
ii libcec2:armhf 2.1.4-2 armhf USB CEC Adaptor communication Library (shared library)
ii libcec4:armhf 4.0.1+dfsg1-1 armhf USB CEC Adaptor communication Library (shared library)
ii vero3-libcec-osmc 4.0.2-5 armhf libcec
rc libcec2:armhf 2.1.4-2 armhf USB CEC Adaptor communication Library (shared library)
And also when executing cec-client ::
libCEC version: 4.0.2, compiled on Sat May 27 17:22:08 UTC 2017 by root@compiler2 on Linux 3.16.0-4-amd64 (armv7l), features: P8_USB, DRM, P8_detect, AOCEC
Found devices: 1
