Library help
Hi!
Afer kodi 21.1 update i get some samples of movies shown in movie library as movies, so i have movie poster and sample poster as two identical movies. How to disable that?
Thank you!
Please check if this is the same issue?
Hi!
Yes this is the same issue.
Thank you!
