I am having an issue with media library on OSMC. It says on the main page “Media Center 506 Movies” However within the movies category only 223 items display. I have tried removing one of the sources and added it back and that didn’t solve anything. I am also able to go to files and and play the movies that are not showing through the source so the files are fine. Any suggestions?
You might have any kind of filter active for your library? Otherwise check if the items that are not showing up in your library have proper scrapped metdadata information. Try under the file node to open up the info tab on your movie file, is it populated?
Everything was fine before and I made no major changes. All the file paths still work just fine on Plex, so I am assuming it has something to do with Kodi.
