I use software (zotero & joplin) which sync across different devices using WebDav. I’m wondering what would be the best approach to install webdav? I’m aware Nextclould has that function but seems overkill; and similarly, installing apache to use webdav. Also, only need for my LAN (don’t need external access).
Is there a light-weight package that can be installed on osmc?
thanks for any advice
