(Sorry if this may be somewhat off-topic, but there is so much Linux wisdom in here, I though I would try and take advantage of it
First off, I have OSMC running beautifully on a RPi 2. I managed to get it installed, set its fixed Wi-Fi IP, etc. thanks to all your kind help and great work. I canāt wait for āstableā versions, though I find Alpha 4 quite stable already.
My setup is almost perfect now, and all I need to add is Live TV + recording capabilities, which I want to do with a Tvheadend or MythTV backend on a separate machine. My plan is to use an old machine and install Ubuntu 14.04 or 14.10 to use it with the Kworld UB435-Q V3 TV Stick.
Interestingly enough, that stick works not only on a Win 7 laptop, but also out-of-the-box on the RPi2 / OSMC.
Sadly, I have not managed to make it work on the backend Ubuntu machine. I upgraded the kernel to >3.16, and the USB device seems well recognized according to dmesg. (My output is the same as the V3 here: KWorld UB435-Q USB ATSC TV stick - LinuxTVWiki )
I can scan and lock channels/services/muxes, and both MythTV and Tvheadend detect my local frequencies/stations (tried both backend software pieces separately, not running concurrently). I can even get some OTA EPG to show up on the Piās OSMC interface, so I am definitely receiving something. The deviceās red LED will light up when tuned to an actual channel.
So it all looks like it would work, butā¦
ā¦unfortunately, when I try to watch the remote feeds (any channel/service), the picture is unrecognizable (big colored patches with some bizarre pixelated spots), sound is just a digital buzz and eventually the feed cuts off because there are too many errors. Am I missing something ? (Codec ? Firmware ? ā¦?)
P.S. Again, the USB device works fine when re-plugged in Windows or directly on the RPi2, so signal reception or antenna placement is not an issue.
Thanks !
