I’m using a Raspberry Pi 3 with the latest Krypton test build (16.8-161).
I built a new skin based on Estouchy to better use a touchscreen. Within this new skin I made a new window on the home screen, which is supposed to control an led strip by using an infrared LED.
I prepared LIRC and it works with sending commands via SSH like irsend -d /run/lirc/lircd-lirc0 SEND_ONCE "LED" "KEY_POWER"
. I’m aware that it doesn’t work without the ‘-d /run/lirc/lircd-lirc0’.
I configured a button with <onclick>LIRC.Send(SEND_ONCE LED KEY_POWER</onclick>
. Unfortunately that doesn’t work. The only thing that works is calling a script: <onclick>System.Exec(/home/osmc/Skripte/off.sh)</onclick>
. The downside by using a shell script is that the audio stucks when pressing that button on the touchscreen.
Is there any solution to directly using ‘LIRC.Send’?
