I’m using osmc on 2 RPi3 with separate TVHeadEnd client and server Pis.
After updating to osmc 2020-10 build my IR remote control no longer works. I can access using an HDMI remote, but this does not allow be to access all functions.
In the Pi Config page there is no longer an options to enable LIRC. Instead there is a warning:
“Warning: GPIO remote support with default pins incompatible with HiFiBerry and I……”
After the update my /boot/config.txt had the entry:
dtoverlay=gpio-ir,gpio_pin=18
I tried changing the pin to 23 and moving the IR reveiver pin accordingly, but the warning message was the same and the remote still does not work.
reproduce the issue
As requested enabled logging and rebooted twice as requested.
To recreate the problem I simply tried to use the IR remote (which didn’t work), so I’m not sure that will show anything directly. I proceeded to use my HDMI remote to carry out the log upload.
Did you learn the lircd.conf profile yourself using irrecord ? I notice it is using raw codes, instead of normal protocol decoders, and I wonder if that is the issue. What kind of remote is it ?
Lircd seems to be loading normally so my suspicion is the profile with raw codes is not working with this newer version of lirc. I’ve never used the raw codes syntax myself as irrecord usually tries to detect the protocol in use and use protocol specific button codes.
It’s a few years since I create the conf file. I did indeed create it ‘from scratch’ and it uses a WD TV Live remote control. I can’t remember how exactly I created it - presumably using irrecord or something similar.
Using irrecord -1 I was able to create much simplified conf file (see below). However, the remote still does not work. I’ve reverted back to pin 18 that I used originally.
I’m still a bit confused as to what’s happened to the ‘Enable LIRC’ option. Is this not required any more?
Is there an easy way to make sure the IR hardware is working?
begin remote
name /home/pi/lircd.conf
bits 32
flags SPACE_ENC|CONST_LENGTH
eps 30
aeps 100
header 8988 4429
one 599 1652
zero 599 556
ptrail 599
gap 107435
toggle_bit_mask 0x0
frequency 38000
You can test the IR hardware and receiver using mode2 - before using mode2 or irrecord you need to stop lircd which can be done like this:
sudo systemctl stop lircd_helper@lirc0
Then run mode2 -d /dev/lirc0
When you press buttons on any remote at all you should see mark space lines scrolling by. If you do the IR receiver is working and the /dev/lirc0 device driver which lircd connects to is working. This also confirms you have the correct GPIO pin, as if you don’t you will get nothing.
To restart lircd when you’re finished using irrecord or mode 2 just run sudo systemctl restart lircd_helper@lirc0 or reboot.
If you still can’t get it working I would be inclined to try learning the remote again with irrecord.
I got mode2 to work as suggested. I had to install a new remote IR receiver, so something happened to the old one. It seems odd that it failed coincident with software upgrade, but nevertheless the new one works using pin 18 (some as original pin).
I used irrecord to re-learn remote. It is different to that analyzed from the old learned conf file.
However, still no joy getting it to work with osmc.
I’ve created a new debug log in case there’s anything I’ve messed up whilst trying to get it working. This of course also shows the new remote config : https://paste.osmc.tv/kusedeneda
What do you see if you run irw /var/run/lirc/lircd and press buttons on the remote ?
Are you sure that irrecord recorded the remote properly, and that you used the correct key names when you named each key ?
I notice this error in your log:
Oct 21 14:56:17 osmc-james lircd-0.9.4c[275]: Notice: /etc/lirc/lircd.conf: wd-tv-live: Multiple values for same code: KEY_8
Oct 21 14:56:17 osmc-james lircd-0.9.4c[275]: Notice: /etc/lirc/lircd.conf: wd-tv-live: Multiple values for same code: KEY_SEARCH
Oct 21 14:56:17 osmc-james lircd-0.9.4c[275]: Notice: /etc/lirc/lircd.conf: wd-tv-live: Multiple values for same code: KEY_0
This may suggest that the remote has not been learnt properly although I don’t see anything visually wrong with your lircd.conf file. Clearly lircd is not happy with it though.
Another thing I’ve noticed is your config file has a line saying “driver devinput”. We don’t use the devinput driver on lircd, we use the “default” driver when we launch lircd.
Did you manually specify the “devinput” driver when using irrecord perhaps ? It might be worth removing that line from the conf and see what happens. I have a hunch that might fix it for you.
Running irw /var/run/lirc/lircd gives no response at all to key presses!
The driver devinput was inserted automatically when I used “irrecord -d /dev/lirc0” to record the remote.
Removing the line made no difference to the result
I re-recorded just the offending keys mentioned in the error message and updated the conf file. There are now no error messages see - https://paste.osmc.tv/sidetororo
decode value. That made me a bit concerned as I cannot see how it would work if there was no consistent output!
Despite your great efforts to help me I feel like I’m going backwards!
Unfortunately I’m out of ideas for the moment. The IR receiver is clearly working and able to record valid looking codes with irrecord, so I don’t understand why lircd will not decode them.
When using irrecord I had been using the command: irrecord --device /dev/lirc0
This is why I was getting devinput.
I then tried irrecord --device /dev/lirc0 --driver default
However, this then would not complete properly, reporting that it could not find the gap:
It is very important that you press many different buttons randomly
and hold them down for approximately one second. Each button should
generate at least one dot but never more than ten dots of output.
Don’t stop pressing buttons until two lines of dots (2x80) have
been generated.
Press RETURN now to start recording.
Got gap (107387 us)}
Please keep on pressing buttons like described above.
…Cannot find any gap, using an arbitrary 50 ms one. If you have a
regular remote for e. g., a TV or such this is probably a point
where you hit control-C. However, technical hardware like air
condition gear often works without any gap. If you think it’s
reasonable that your remote lacks gap you can proceed.
Press RETURN to continue.
I remember seeing this before, but wasn’t sure why this was unique to Pi.
If it is – it’s going to be a pain to fix it. There may be a better solution.
