I’m running OSMC October 2015.2015-10-1 with a generic infrared remote control using lirc and a GPIO infrared receiver.
The remote has been working up to now and it works fine just after OSMC boots. IF I leave the system alone for a while then the IR remote stops working (though OSMC continues to respond to the Kodi remote on my iPhone).
Any ideas why the remote just stops working?
Here is the content of my lirc conf file:
begin remote
name /home/osmc/lircd.conf
bits 16
flags SPACE_ENC|CONST_LENGTH
eps 30
aeps 100
header 9105 4482
one 616 1647
zero 616 512
ptrail 623
repeat 9094 2213
pre_data_bits 16
pre_data 0xFF
gap 108419
toggle_bit_mask 0x0
begin codes KEY_FASTFORWARD 0x02FD KEY_REWIND 0x22DD KEY_VOLUMEUP 0xA857 KEY_VOLUMEDOWN 0xE01F KEY_PLAYPAUSE 0xC23D KEY_UP 0x18E7 KEY_DOWN 0x4AB5 KEY_RIGHT 0x5AA5 KEY_LEFT 0x10EF KEY_OK 0x38C7 KEY_STOP 0x42BD KEY_BACK 0x30CF end codes
end remote
