I’ve tried to use remote control from Creative Sound Blaster X-fi 5.1 sound card which I suppose needs alsa_usb driver compiled into lirc. Is there a reason that this driver is not within standard armv7-remote-osmc package?
Regards,
Vit3c
Regards,
Vit3c
See my post here, if you haven’t already ![]()
I think this is built in driver:
http://www.lirc.org/html/alsa-usb_driver.html
Not sure if available in 0.9.0.
Anyway I give up on this device because I can’t get 5.1 audio working on it. So won’t use ir receiver either.
Thanks for answer.
It look like the soundcard is supporting 5.1 channels now on OSMC, but i cannot get the remote to work I have the lirc.conf for the remote, i’ve added it to /etc/lirc folder.
Any way i can make this work? Will install lirc from sources work or mess with OSMC?
It looks like this:
begin remote
name Creative_RM-1800
bits 16
flags SPACE_ENC|CONST_LENGTH
eps 30
aeps 100
header 9078 4671
one 663 1607
zero 663 497
ptrail 662
repeat 9078 2216
pre_data_bits 16
pre_data 0x8322
gap 106974 300000
toggle_bit_mask 0x0
begin codes
KEY_POWER 0x619E # Was: Power
X_KEY_4bit 0x916E # Was: KEY_4bit
X_KEY_4bit_Up 0x926D # Was: KEY_4bit_Up
X_KEY_4bit_Down 0x936C # Was: KEY_4bit_Down
CMSS 0x718E
CMSS_Up 0x946B
CMSS_Down 0x956A
EAX 0x8C73
EAX_Up 0x9669
EAX_Down 0x9768
X_KEY_3dMidi 0x9867 # Was: KEY_3dMidi
X_KEY_3dMidi_Up 0x9966 # Was: KEY_3dMidi_Up
X_KEY_3dMidi_Down 0x9A65 # Was: KEY_3dMidi_Down
KEY_MUTE 0x6E91 # Was: Mute
KEY_VOLUMEUP 0x629D # Was: Vol_Up
KEY_VOLUMEDOWN 0x639C # Was: Vol_Down
KEY_UP 0x7B84 # Was: Up
KEY_LEFT 0x6B94 # Was: Left
KEY_RIGHT 0x728D # Was: Right
KEY_REWIND 0x8778 # Was: Rew
KEY_OK 0x817E # Was: Ok
KEY_FORWARD 0x758A # Was: Fwd
KEY_DOWN 0x8D72 # Was: Down
KEY_ENTER 0x8E71 # Was: Return
KEY_PLAY 0x8877 # Was: Start
KEY_CANCEL 0x7C83 # Was: Cancel
KEY_RECORD 0x738C # Was: Rec
KEY_OPTION 0x827D # Was: Options
Display 0x7689
KEY_PREVIOUS 0x7F80 # Was: Previous
KEY_PLAY 0x7986 # Was: Play
KEY_NEXT 0x7A85 # Was: Next
KEY_SLOW 0x7D82 # Was: Slow
KEY_STOP 0x857A # Was: Stop
KEY_1 0x8B74 # Was: 1
KEY_2 0x8F70 # Was: 2
KEY_3 0x906F # Was: 3
KEY_4 0x8A75 # Was: 4
KEY_5 0x847B # Was: 5
KEY_6 0x7887 # Was: 6
KEY_7 0x8976 # Was: 7
KEY_8 0x837C # Was: 8
KEY_9 0x7788 # Was: 9
KEY_0 0x807F # Was: 0
end codes
end remote
