If you need streams to work now get that and if you in the future dont want to be on a alpha build delete that and install new stable once that is released… Or maybe kodi will automatically update from alpha7 to new stable once new stable is out I don’t know.
I’ve just discovered that YouTube live streams are broken, although I’m still on an older build where they previously worked.
sudo uname -a
Linux Osmc_Vero_4K 3.14.29-132-osmc #1 SMP Mon Nov 26 00:05:01 UTC 2018 aarch64 GNU/Linux
All the multiple mpeg-dash settings are still in place. There is no update available to the YouTube plug-in that I can see.
I looked at the massive thread on the Kodi forum, however the recent discussions are about installations on Android, and beta versions which don’t seem to work.
Should I just leave this alone until the next osmc update, or will it not help?
