I’m using the Raspberry Pi 3B+ and wanted to watch ZDF
live stream with the addon MediathekView
. The Raspberry is connected via WiFi, but it should be a stable connection. When trying to start the live stream for the first time, the live stream works fine. If the stream gets stopped and started again later, it won’t work. The error is something like File couldn't be played. Please see log.
I tried starting t multiple times. After reboot, a few hours later and other streams from the addon. It works maybe one out of 10 times.
Here is my logfile for one attempt: https://paste.osmc.tv/mozujokiri
I could find the lines:
13:21:59.893 T:1905259264 DEBUG: CurlFile::Open(0x718fe610) http://zdf1314-lh.akamaihd.net/i/de14_v1@392878/master.m3u8
13:21:59.994 T:1905259264 ERROR: CCurlFile::FillBuffer - Failed: Couldn’t resolve host name(6)
13:21:59.994 T:1905259264 ERROR: CCurlFile::Open failed with code 0 for http://zdf1314-lh.akamaihd.net/i/de14_v1@392878/master.m3u8
I never had problems to resolve urls for example when I ran the same raspberry with same wifi connection and raspbian. Is there an option to lower the occurences of this error or is there a different cause?
Thanks in advance
