Just a quick question i can’t seem to google an anwser for
When i enter the Live tv - Dvr menu today it starts on the timeline.
I then have to go into options and change it to display channels.
but doing this every time is becoming very boring
is there a way i can set it to channels by default?
Which skin are you using? If it’s the OSMC skin, you may go to the skin settings and use the Customise home menu option to adjust the path the PVR home menu entry is pointing to.
Indeed, I went into skin settings and enabled “Customise home menu”
It then installede som addons and now I can set the default window for Live Tv to “TV Channels”
