There does not seem to be an option to record a TV series, only a single episode.
If I swap the skin to the default confluence skin, I have the option to record a show every day, every week, or one off.
Is this a current limitation or a bug?
You should use the tvheadend webui if you use tvheadend for your tuner… > http://osmc.local:9981
but it is with limited support also because it depend on what EPG info you use.
-H
