Live TV save location and mounting networked hard drive
Solved in posted #2
I have tried mounting a networked hard drive in OSMC via fstab
//10.1.1.19/data /mnt/data cifs nobrl,uid=1000,sec=ntlmv2,user=pi,pass=pass
however, when I do sudo “mount -a” the drive does not appear when I do df -h.
Also, where would the videos get saved if they are configured to save on the external
hard but and reported the hard drive is not mounting and TVHeadend is not reporting
the video recording failed.
Thanks,
Aaron
I suggest you check this fstab entry
If the Harddisk is not mounted it depends. If the folder doesn’t exists the recording would be lost. If the fodler exists it would be saved to the SD card
Thank, that solution worked! I think it was failing because I was thinking it was asking to the username and password of the other pi rather than the one running osmc.
