dmesg log
====================== Kernel Message Log =================== Ad2zzd21
[ 0.000000] Booting Linux on physical CPU 0xf00
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.0-1-osmc (root@vero) (gcc version 4.9.2 (Debian 4.9.2-10) ) #1 SMP PREEMPT Tue Jan 12 17:56:48 UTC 2016
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine model: Raspberry Pi 2 Model B Rev 1.1
[ 0.000000] cma: Reserved 8 MiB at 0x2e400000
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] On node 0 totalpages: 192512
[ 0.000000] free_area_init_node: node 0, pgdat 80bbd780, node_mem_map add64000
[ 0.000000] Normal zone: 1692 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 192512 pages, LIFO batch:31
[ 0.000000] [bcm2709_smp_init_cpus] enter (9660->f3003010)
[ 0.000000] [bcm2709_smp_init_cpus] ncores=4
[ 0.000000] PERCPU: Embedded 13 pages/cpu @aefac000 s23552 r8192 d21504 u53248
[ 0.000000] pcpu-alloc: s23552 r8192 d21504 u53248 alloc=13*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 190820
[ 0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1920 bcm2708_fb.fbheight=1080 bcm2709.boardrev=0xa21041 bcm2709.serial=0x96af790b smsc95xx.macaddr=B8:27:EB:AF:79:0B bcm2708_fb.fbswap=1 bcm2709.uart_clock=3000000 bcm2709.disk_led_gpio=47 bcm2709.disk_led_active_low=0 sdhci-bcm2708.emmc_clock_freq=250000000 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000 root=/dev/mmcblk0p2 rootfstype=ext4 rootwait quiet osmcdev=rbp2
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 741152K/770048K available (7941K kernel code, 436K rwdata, 1860K rodata, 1788K init, 764K bss, 20704K reserved, 8192K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xaf800000 - 0xff800000 (1280 MB)
lowmem : 0x80000000 - 0xaf000000 ( 752 MB)
modules : 0x7f000000 - 0x80000000 ( 16 MB)
.text : 0x80008000 - 0x8099a69c (9802 kB)
.init : 0x8099b000 - 0x80b5a000 (1788 kB)
.data : 0x80b5a000 - 0x80bc7384 ( 437 kB)
.bss : 0x80bca000 - 0x80c8926c ( 765 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 32.
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] Architected cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000010] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.000032] Switching to timer-based delay loop, resolution 52ns
[ 0.000329] Console: colour dummy device 80x30
[ 0.000557] console [tty0] enabled
[ 0.000585] Calibrating delay loop (skipped), value calculated using timer frequency… 38.40 BogoMIPS (lpj=192000)
[ 0.000612] pid_max: default: 32768 minimum: 301
[ 0.000963] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000986] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.002211] Disabling cpuset control group subsystem
[ 0.002264] Initializing cgroup subsys io
[ 0.002296] Initializing cgroup subsys memory
[ 0.002349] Initializing cgroup subsys devices
[ 0.002373] Initializing cgroup subsys freezer
[ 0.002397] Initializing cgroup subsys net_cls
[ 0.002470] CPU: Testing write buffer coherency: ok
[ 0.002553] ftrace: allocating 19374 entries in 57 pages
[ 0.049803] CPU0: update cpu_capacity 1024
[ 0.049844] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[ 0.049860] [bcm2709_smp_prepare_cpus] enter
[ 0.050005] Setting up static identity map for 0x8240 - 0x8298
[ 0.129397] [bcm2709_boot_secondary] cpu:1 started (0) 17
[ 0.129760] [bcm2709_secondary_init] enter cpu:1
[ 0.129818] CPU1: update cpu_capacity 1024
[ 0.129827] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[ 0.159426] [bcm2709_boot_secondary] cpu:2 started (0) 17
[ 0.159696] [bcm2709_secondary_init] enter cpu:2
[ 0.159730] CPU2: update cpu_capacity 1024
[ 0.159739] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[ 0.189513] [bcm2709_boot_secondary] cpu:3 started (0) 17
[ 0.189763] [bcm2709_secondary_init] enter cpu:3
[ 0.189794] CPU3: update cpu_capacity 1024
[ 0.189802] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[ 0.189895] Brought up 4 CPUs
[ 0.189925] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.189935] CPU: All CPU(s) started in HYP mode.
[ 0.189944] CPU: Virtualization extensions available.
[ 0.190827] devtmpfs: initialized
[ 0.201719] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.202194] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.203252] pinctrl core: initialized pinctrl subsystem
[ 0.204077] NET: Registered protocol family 16
[ 0.209555] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ 0.239645] cpuidle: using governor ladder
[ 0.269677] cpuidle: using governor menu
[ 0.276607] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.276626] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.276807] Serial: AMBA PL011 UART driver
[ 0.277110] 3f201000.uart: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
[ 0.277803] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ 0.351359] bcm2835-dma 3f007000.dma: DMA legacy API manager at f3007000, dmachans=0x1
[ 0.353309] SCSI subsystem initialized
[ 0.353543] usbcore: registered new interface driver usbfs
[ 0.353668] usbcore: registered new interface driver hub
[ 0.353833] usbcore: registered new device driver usb
[ 0.359916] raspberrypi-firmware soc:firmware: Attached to firmware from 2016-01-29 13:52
[ 0.387099] clocksource: Switched to clocksource arch_sys_counter
[ 0.439334] FS-Cache: Loaded
[ 0.439786] CacheFiles: Loaded
[ 0.456249] NET: Registered protocol family 2
[ 0.457554] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.457693] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.457885] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.458016] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.458082] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.458439] NET: Registered protocol family 1
[ 0.458967] RPC: Registered named UNIX socket transport module.
[ 0.458986] RPC: Registered udp transport module.
[ 0.458997] RPC: Registered tcp transport module.
[ 0.459008] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.571504] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[ 0.574077] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.574265] audit: initializing netlink subsys (disabled)
[ 0.574342] audit: type=2000 audit(0.539:1): initialized
[ 0.589793] VFS: Disk quotas dquot_6.6.0
[ 0.590182] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.592960] FS-Cache: Netfs ‘nfs’ registered for caching
[ 0.594105] NFS: Registering the id_resolver key type
[ 0.594176] Key type id_resolver registered
[ 0.594189] Key type id_legacy registered
[ 0.597702] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 0.597913] io scheduler noop registered
[ 0.598472] io scheduler bfq registered (default)
[ 0.598485] BFQ I/O-scheduler version: v7r7
[ 0.601256] BCM2708FB: allocated DMA memory ee800000
[ 0.601306] BCM2708FB: allocated DMA channel 0 @ f3007000
[ 0.635458] Console: switching to colour frame buffer device 240x67
[ 1.740039] bcm2835-rng 3f104000.rng: hwrng registered
[ 1.740197] vc-cma: Videocore CMA driver
[ 1.740213] vc-cma: vc_cma_base = 0x00000000
[ 1.740224] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 1.740235] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 1.740560] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
[ 1.761558] brd: module loaded
[ 1.773043] loop: module loaded
[ 1.774179] vchiq: vchiq_init_state: slot_zero = 0xae880000, is_master = 0
[ 1.776046] Loading iSCSI transport class v2.0-870.
[ 1.776951] usbcore: registered new interface driver smsc95xx
[ 1.777035] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.977496] Core Release: 2.80a
[ 1.977518] Setting default values for core params
[ 1.977545] Finished setting default values for core params
[ 2.177967] Using Buffer DMA mode
[ 2.177987] Periodic Transfer Interrupt Enhancement - disabled
[ 2.177997] Multiprocessor Interrupt Enhancement - disabled
[ 2.178009] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 2.178027] Dedicated Tx FIFOs mode
[ 2.178449] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xae814000 dma = 0xee814000 len=9024
[ 2.178491] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
[ 2.178540] dwc_otg: Microframe scheduler enabled
[ 2.178631] WARN::hcd_init_fiq:413: FIQ on core 1 at 0x80570454
[ 2.178651] WARN::hcd_init_fiq:414: FIQ ASM at 0x805707c4 length 36
[ 2.178672] WARN::hcd_init_fiq:439: MPHI regs_base at 0xaf87e000
[ 2.178766] dwc_otg 3f980000.usb: DWC OTG Controller
[ 2.178839] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 2.178896] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
[ 2.178951] Init: Port Power? op_state=1
[ 2.178962] Init: Power Port (0)
[ 2.179284] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.179305] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.179322] usb usb1: Product: DWC OTG Controller
[ 2.179338] usb usb1: Manufacturer: Linux 4.4.0-1-osmc dwc_otg_hcd
[ 2.179354] usb usb1: SerialNumber: 3f980000.usb
[ 2.180512] hub 1-0:1.0: USB hub found
[ 2.180585] hub 1-0:1.0: 1 port detected
[ 2.181394] dwc_otg: FIQ enabled
[ 2.181409] dwc_otg: NAK holdoff enabled
[ 2.181419] dwc_otg: FIQ split-transaction FSM enabled
[ 2.181463] Module dwc_common_port init
[ 2.181864] usbcore: registered new interface driver usb-storage
[ 2.182248] mousedev: PS/2 mouse device common for all mice
[ 2.182901] usbcore: registered new interface driver usbtouchscreen
[ 2.183217] bcm2835-cpufreq: min=600000 max=900000
[ 2.185722] sdhci: Secure Digital Host Controller Interface driver
[ 2.185731] sdhci: Copyright(c) Pierre Ossman
[ 2.186103] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
[ 2.186116] mmc-bcm2835 3f300000.mmc: DMA channels allocated
[ 2.217260] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.217803] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.218042] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.218263] usbcore: registered new interface driver usbhid
[ 2.218273] usbhid: USB HID core driver
[ 2.218714] Initializing XFRM netlink socket
[ 2.218751] NET: Registered protocol family 17
[ 2.218895] Key type dns_resolver registered
[ 2.219036] Registering SWP/SWPB emulation handler
[ 2.219870] registered taskstats version 1
[ 2.220047] vc-sm: Videocore shared memory driver
[ 2.220060] [vc_sm_connected_init]: start
[ 2.220593] [vc_sm_connected_init]: end - returning 0
[ 2.223574] Freeing unused kernel memory: 1788K (8099b000 - 80b5a000)
[ 2.254488] mmc0: host does not support reading read-only switch, assuming write-enable
[ 2.256470] mmc0: new high speed SDHC card at address 0001
[ 2.257306] mmcblk0: mmc0:0001 00000 29.8 GiB
[ 2.258521] mmcblk0: p1 p2
[ 2.377305] Indeed it is in host mode hprt0 = 00021501
[ 2.471002] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 2.481486] fsck: E2fsck run: /bin/e2fsck -p -C 0 /dev/mmcblk0p2
[ 2.481729] fsck: Filesystem UUID: aeba5263-7d24-4c6c-8e47-7d2cb937722a
[ 2.481987] fsck: /dev/mmcblk0p2: clean, 52017/1941504 files, 520898/7752448 blocks
[ 2.557167] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 2.557320] Indeed it is in host mode hprt0 = 00001101
[ 2.757480] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ 2.757491] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.758383] hub 1-1:1.0: USB hub found
[ 2.758486] hub 1-1:1.0: 5 ports detected
[ 3.037213] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 3.137553] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 3.137581] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.140530] smsc95xx v1.0.4
[ 3.200677] smsc95xx 1-1.1:1.0 eth0: register ‘smsc95xx’ at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:af:79:0b
[ 3.437241] usb 1-1.2: new full-speed USB device number 4 using dwc_otg
[ 3.546105] usb 1-1.2: New USB device found, idVendor=1997, idProduct=2433
[ 3.546131] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.546143] usb 1-1.2: Product: Keyboard
[ 3.546155] usb 1-1.2: Manufacturer: Kano
[ 3.554946] input: Kano Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.0/0003:1997:2433.0001/input/input0
[ 3.608343] hid-generic 0003:1997:2433.0001: input,hidraw0: USB HID v1.01 Keyboard [Kano Keyboard] on usb-3f980000.usb-1.2/input0
[ 3.616051] input: Kano Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.1/0003:1997:2433.0002/input/input1
[ 3.667865] hid-generic 0003:1997:2433.0002: input,hidraw1: USB HID v1.01 Mouse [Kano Keyboard] on usb-3f980000.usb-1.2/input1
[ 3.747230] usb 1-1.5: new high-speed USB device number 5 using dwc_otg
[ 3.864797] usb 1-1.5: New USB device found, idVendor=148f, idProduct=5370
[ 3.864822] usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3.864834] usb 1-1.5: Product: 802.11 n WLAN
[ 3.864845] usb 1-1.5: Manufacturer: Ralink
[ 3.864856] usb 1-1.5: SerialNumber: 1.0
[ 3.999087] random: systemd urandom read with 78 bits of entropy available
[ 4.059078] NET: Registered protocol family 10
[ 4.367350] systemd[1]: Cannot add dependency job for unit display-manager.service, ignoring: Unit display-manager.service failed to load: No such file or directory.
[ 4.367586] systemd[1]: Found ordering cycle on basic.target/start
[ 4.367609] systemd[1]: Found dependency on sysinit.target/start
[ 4.367629] systemd[1]: Found dependency on kbd.service/start
[ 4.367647] systemd[1]: Found dependency on remote-fs.target/start
[ 4.367665] systemd[1]: Found dependency on remote-fs-pre.target/start
[ 4.367681] systemd[1]: Found dependency on connman.service/start
[ 4.367697] systemd[1]: Found dependency on dbus.service/start
[ 4.367714] systemd[1]: Found dependency on basic.target/start
[ 4.367731] systemd[1]: Breaking ordering cycle by deleting job kbd.service/start
[ 4.367751] systemd[1]: Job kbd.service/start deleted to break ordering cycle starting with basic.target/start
[ 4.368047] systemd[1]: Found ordering cycle on basic.target/start
[ 4.368070] systemd[1]: Found dependency on sysinit.target/start
[ 4.368090] systemd[1]: Found dependency on rpcbind.service/start
[ 4.368108] systemd[1]: Found dependency on network-online.target/start
[ 4.368125] systemd[1]: Found dependency on network.target/start
[ 4.368142] systemd[1]: Found dependency on connman.service/start
[ 4.368158] systemd[1]: Found dependency on dbus.service/start
[ 4.368174] systemd[1]: Found dependency on basic.target/start
[ 4.368191] systemd[1]: Breaking ordering cycle by deleting job rpcbind.service/start
[ 4.368211] systemd[1]: Job rpcbind.service/start deleted to break ordering cycle starting with basic.target/start
[ 4.469626] fuse init (API version 7.23)
[ 4.662910] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 4.914933] systemd-udevd[179]: starting version 215
[ 5.070672] lirc_dev: IR Remote Control driver registered, major 244
[ 5.083809] lirc_rpi: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.100402] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
[ 5.212405] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[ 5.657186] usb 1-1.5: reset high-speed USB device number 5 using dwc_otg
[ 5.658596] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 5.768333] ieee80211 phy0: rt2x00_set_rt: Info - RT chipset 5390, rev 0502 detected
[ 5.776711] random: nonblocking pool is initialized
[ 5.805459] ieee80211 phy0: rt2x00_set_rf: Info - RF chipset 5370 detected
[ 5.876889] ieee80211 phy0: Selected rate control algorithm ‘minstrel_ht’
[ 5.878931] usbcore: registered new interface driver rt2800usb
[ 6.037289] lirc_rpi: auto-detected active high receiver on GPIO pin 18
[ 6.039672] platform lirc_rpi: lirc_dev: driver lirc_rpi registered at minor = 0
[ 6.039703] lirc_rpi: driver registered!
[ 6.507807] input: lircd as /devices/virtual/input/input2
[ 6.520863] systemd-journald[158]: Received request to flush runtime journal from PID 1
[ 7.029251] ieee80211 phy0: rt2x00lib_request_firmware: Info - Loading firmware file ‘rt2870.bin’
[ 7.053661] ieee80211 phy0: rt2x00lib_request_firmware: Info - Firmware detected - version: 0.29
[ 7.354168] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 8.136567] wlan0: authenticate with c0:05:c2:03:c7:89
[ 8.164796] wlan0: send auth to c0:05:c2:03:c7:89 (try 1/3)
[ 8.168361] wlan0: authenticated
[ 8.177213] wlan0: associate with c0:05:c2:03:c7:89 (try 1/3)
[ 8.181231] wlan0: RX AssocResp from c0:05:c2:03:c7:89 (capab=0x431 status=0 aid=1)
[ 8.188558] wlan0: associated
[ 8.188716] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 10.546862] Console: switching to colour dummy device 80x30
---------------------- Kernel Message Log END --------------- Ad2zzd21
lsusb
http://paste.osmc.io/yequleveda
