Everything is work fine but only with monitor connected thought HDMI port.
When monitor is disconnected from Apple TV system is not booting.
The goal is to use Apple TV + OSMC to play music with remote control thought mobile app.
The question is how I can boot system with OSMC without monitor? Is it possible? Thanx!
Hi. This can’t be!! I have 3pcs. not one of them is not loaded. What is your version of osmc? I’ll try to put as yours! But I think osmc is not loaded, video card doesn’t know what resolution to choose and what is the frequency of the screen!
Not only OSMC is not loaded, I think whole system is not loaded without connected monitor. After ATV is ON and pass some time I can’t see the device in the list of connected devices on router. And the led (toslink) on ATV’s box doest’t light. But when the monitor is connected everything is ok, system boot as expected, it appears in connected devices on router and the led (toslink) is lights on.
I’ve run my ATV as a headless server for some months and had no problem booting. Usually, after a reboot I would stop the GUI with ‘sudo systemctl stop mediacenter’ but it was not necessary either way.
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Sun Dec 10 15:32:30 2017 from 10.0.1.12
osmc@osmc:~$ sudo systemctl status mediacenter
mediacenter.service - media center application
Loaded: loaded (/lib/systemd/system/mediacenter.service; enabled)
Active: active (running) since Sun 2017-12-10 16:00:36 MSK; 4min 54s ago
Main PID: 1457 (mediacenter)
CGroup: /system.slice/mediacenter.service
|-1457 /bin/bash /usr/bin/mediacenter
|-2021 sudo -u osmc xinit /usr/lib/kodi/kodi.bin --standalone -fs …
`-2028 xinit /usr/lib/kodi/kodi.bin --standalone -fs --lircdev /va…
Dec 10 16:05:21 osmc mediacenter[1457]: (EE)
Dec 10 16:05:21 osmc mediacenter[1457]: Fatal server error:
Dec 10 16:05:21 osmc mediacenter[1457]: (EE) no screens found(EE)
Dec 10 16:05:21 osmc mediacenter[1457]: Please consult the The X.Org Foundat…t
Dec 10 16:05:21 osmc mediacenter[1457]: at http://wiki.x.org
Dec 10 16:05:21 osmc mediacenter[1457]: for help.
Dec 10 16:05:21 osmc mediacenter[1457]: (EE) Please also check the log file …
Dec 10 16:05:21 osmc mediacenter[1457]: (EE) Server terminated with error (1…
Hint: Some lines were ellipsized, use -l to show in full.
osmc@osmc:~$
