The 2nd line below the NAS mount is:
tmpfs 75104 0 75104 0% /run/user/1000
So if you issue touch /mnt/test.file
on your pi
can you then go to the NAS and see test.file had been created?
I get a touch: cannot touch ‘/mnt/test.file’: Permission denied.
Just to make sure, because I don’t have a good grasp of the file/directory structure, I can only cd to mnt if I am in osmc@osmc:/$
OK.
You probably need to mount the NAS with RW permission. This is why the recordings are not being saved.
This is the syntax I used to get a successful mount.
//192.168.1.3/Public/LiveTV /mnt cifs guest, uid-1000 0 0
Can this be modified to generate R/W permissions?
Thanks again
Pass rw as an option.
Change this to
//192.168.1.3/Public/LiveTV /mnt cifs guest,rw,uid-1000 0 0
Still get the permission denied message.
I also tried “'noperm” instead of “rw” but still got permission denied.
Thanks to you guys at least I know why TVHeadend is not writing.
You may need to authenticate for RW access.
But the /mnt directory is owned by root. So make a /home/osmc/mnt directory instead as OSMC user and adjust fstab to mount there. Then it should work
Ok I created /home/osmc/mnt and changed the etc/fstab file to read:
//nas IP address/Public/LiveTV /home/osmc/mnt cifs quest,rw, uid-1000 0 0
I verified via “df” that the NAS was mounted and it was.
I then entered:
osmc@osmc:~$ touch /home/osmc/mnt/test.file
Error returned:
touch: cannot touch ‘/home/osmc/mnt/testfile’: Permission denied
CORRECTION:
If I entered sudo touch /home/osmc/mnt/test.file I do NOT get an error and a file IS created.
did not know I had to enter 'sudo" for that command.
I changed the TVHeadend/backend “Recording System Path” to “/home/osmc/mnt” and saved that configuration.
I started up a KODI client and tried to record. The client showed it was recording but there still is no file in “MyBookLive/Public/LiveTV”
Getting closer
OSMC runs TVHeadend as ‘osmc’ user.
You need to make sure it’s mount as UID/GID 1000.
Try sudo chown -R osmc:osmc /home/osmc/mnt.
Try
//nas IP address/Public/LiveTV /home/osmc/mnt cifs guest,file_mode=0777,dir_mode=0777, uid-1000 0 0
Did you misspell guest as quest in your fstab or only in your post??
BINGO! The misspelling was only in my post not in fstab
However, the syntax you provided WORKS.
Thanks Dilligaf, Sam, ActionA for sticking with me on this. Rock solid recording.
Now I’ll work on getting the EPG working. I try not to bother the group on this but, as you can see, my Windows skills don’t help me in Linux one iota.
Thanks again guys
Glad you got this working
Could not have done it without the help of you guys. Thanks again
For the EPG, are you in the US?
If so you will likely do better getting EPG data from a listing service rather than OTA, which mostly only shows the current program and the next few hours.
There is a very useful script that can scrape TVGuide.com and create a file (xmltv.xml) that can be piped into TVHeadend.
http://zap2xml.awardspace.info/
You’ll need perl (Perl - Debian Wiki) to run the script, and something to pipe xmltv.xml into TVHeadend. I use socat (standard debian package)
I have my own script which runs the following commands (“-z” specifies TVGuide.com instead of zap2it.com, “-S 1” adds a delay to prevent errors due to too many web page requests too fast)
perl ~/zap2xml.pl -z -S 1 -u TVGuide_user@mail.com -p TVGuide_password -o ~/xmltv.xml -c ~/cache
sudo socat ~/xmltv.xml UNIX-CONNECT:/home/hts/.hts/tvheadend/epggrab/xmltv.sock
Yes I am in the USA I do have a zap2it account and did get zap2xml running on my windows machine and generated an xml file.
Perl, pipe to smltv.xml, socat…leaves me in the dust.
I will research all the great information you posted but I sure stumble when it comes to Linux. Writing 8 core true multitasking assembly programs is a slam dunk for me but Linux remains something just short of Klingon.
Thank you for taking the time to give me some direction.
