I somehow managed to lock myself out of Kodi/OSMC. I have two profiles. After I set the restricted one to use for Autologin for some reason the Settings menu item is gone.
How can I get it back? Can I change the settings for this particular profile to show the Settings item again? Or could I intercept the autologin somehow… and then login to the other profile…
You will always be able to open the shutdown menu… Either through the home menu entry, if it’s still there or by connecting a keyboard and pressing S. That menu has a settings link.
Strange why settings would disappear. By default, the customization options should prevent that from happening, if not explicitly set to off. You’re using the OSMC skin?
I gonna try the keyboard approach (will take a couple of weeks). I deliberately removed the Power menu (I believe) but set the Settings as a Menu item. For some reason it vanished. I could still use it the very same day. It vanished after updating to the latest May release
But you can use Yatse and add a custom command (see here for instructions: Yatse Custom Commands). The command needed would be this one: ActivateWindow(Settings). That will get you directly to the settings window
