Logs filling disks with messages about pvr.teleboy
2022-11-15 22:18:17.924 T:471      INFO <general>: AddOnLog: pvr.teleboy: PARAMS-DB: Failed to get current version.
2022-11-15 22:18:17.924 T:471     ERROR <general>: AddOnLog: pvr.teleboy: PARAMS-DB: Query failed: unable to open database file
At 23 MB a second or so, it fills my disk after a short time then things stop working :frowning:
I don’t have a PVR attached…
You could disable this add-on if you’re not using it.
I would, if I could figure out how?
Otherwise it might be reinstall time…
Should be under Settings → Add-Ons
Yeah, there were no add-ons at all. However, there was some db corruption, so I ended up reinstalling (which was really painlessly slick).
Thanks!
I’m glad this is now solved – in future if it came to it, you could use My OSMC’s Factory Reset option to delete the Kodi userdata directory.
