I noticed a sound of something loose inside my Vero 4k after traveling. I opened up the case and sure enough there was a loose screw but I can’t tell where it goes. I have attached picture. Can anyone tell me where it goes?
In the bin. There are only 4 screws in the Vero - the three that you see in your picture and one (silver) that holds the heat sink.
Was about to say the same.
Bin it or keep it in your toolbox. The board is mounted solidly to the case, so shouldn’t give you any problems.
ok thank you
