After updating Osmc, the customizations I made to the main menu are gone. And I have to reapply them. This happened the last 2 updates and also sometime before that.
Is there a way to specifically backup and restore the menu? Or can you help me to troubleshoot this?
Before the next update I suggest to enable debug logging as it will give you more chances to see what happens.
For now I recommend to upload default logs without rebooting via MyOSMC
reproduce the issue
