Previous versions placed a dot next to videos in my library that had been played. This feature seems to be gone in current version. Also if I exit and then restart a video it no longer seems to remember where I was. Is there a settings option for these? Thanks
No such issue is known, so you would need to provide debug enabled logs for us to help you.
reboot the OSMC device
reproduce the issue
upload the log set either using the
