I recently lost the ability to control my Raspberry 2 running OSMC with my TV remote.
I have a fairly new Samsung TV and the remote that came with it. It’s been working flawless for controlling OSMC for months. It worked out of the box - I haven’t done any settings to get it to work, as far as I can recall.
Just a few days ago, the remote no longer work for OSMC. Still works for the TV.
I have recently set up a soundbar system to the TV (via HDMI), but I believe the remote still worked after that. In either case, removing the soundbar doesn’t give remote control back.
I also installed updates to OSMC at about the same time, probably after setting up the soundbar. I think it’s more likely the problem arose from there.
I have checked My OMSC for remote settings, but so far without any luck in getting the remote back online.
Any ideas on how to fix this?
