I found something, all test before (more then 40) i’ve do was with ssh systemctl restart mediacenter, now I’ve beginning to use the kodi ,menu reset “Kodi box”.
and after three trys, i fall back to the OSMC skin.
What i know that i’ve the guisettings.xml three times
in .kodi/userdata
in .kodi/userdata/profiles
in .kodi/userdata/profiles/michael
Only the first file was be change to skin OSMCdefault; and when I replace this gui*.xml with my origin *settings.xml, it’s works fine.
I’ve the log files if you need,
Michael
Hi Sam
For now I’ve test the (first +second) avril update:
3 days with profile login page enabled
1 day with auto login profile enabled.
It’s work’s … (to be sure I prefer to wait for 1 week or more)
Now i update my prod box with avril update (using profile login page)
and with the other box I always take a look to autologin (profile)
I hope that quickly I can write that you are “The Venerable Bouddha”.
Because when other peoples laugh, you work…
Michael
PS: I’buy some Vero’s box, Your and your team take the time to continuous …Myself, I’ve really a problem with peoples which don’t donate, don’t buy Vero, etc…
